if i access shared folders from onedrive, the folders are empty.
how can i use shared folders from onedrive in Netdrive3?
I’m really sorry about that. There was a bug and will fixed next version.
After update you should delete/create your drive again then you should access to your shared folder correctly.
Thanks!
thanks for your answer!
then, when it will be updated??
I’ll let you know when it’s scheduled. Thanks!
