hello
i want to upgrade from netdrive 1 to 2 or 3
i tried both but i have a problem that was not on version 1
actually if i don’t refresh the folder content with a right click it don’t update
i need to have a faster refresh rate for an ftp folder, is there an option for that?
regards
Thank you for using NetDrive
Could you try with setting an option “Always retrieve file list from server”?
You can see that a configuration of a drive item.
hello
it is already but refresh is still too slow
Le jeu. 13 févr. 2020 à 03:06, jyyoon@bdrive.com via Bdrive Support Forum - NetDrive and CloudSync no-reply@bdrive.com a écrit :
This is because the file list also uses the cache for performace.
If you turn on “Always retrieve file list from server” option, the cache of file list is expired in 3 seconds.
In your case, you use “Refresh” menu.
