Hi.
When creating files on FTP drive: File System Error 65535
How can I solve the problem ?
It was works In NetDrive2.
Help, please !
Thanks for the log file.
Please remove subdirectory path from server URL like this:
If you want to add subdirectory name on the URL use BROWSE button to select sub folder.
I think it will fix your problem.
Everything is OK now.
Thx !!!
