Hi, netdrive looping.
No kernel extension allowed
I also tried checking whether the Kernel extension is allowed as ysh suggested
and it all looked OK, but Netdrive not working
I also tried the above and NetDrive Kernel extension is allowed.
Rebooted many times uninstalled and re-installed both v 3.13.300 and 3.13.292 without success.
When I try to connect the App crashes and have to force quit it.
You can check kernel extension version and last modified date with following steps:
- Click Apple Logo at upper left corner of your screen
- Click âAbout This Macâ
- Click âSystem Reportâ
- Select âSoftware > Extensionsâ
here the same⌠
I see the extension twice there and dated July 2020, although I reinstalled the software in Nov 2020.
I donât know what caused the duplication but the date is okay.
We added support for Big Sur while it was a beta.
@tucnyj, @bdd0-info, @doonyuen, @santosh-thomas8, @avart, @tonio-lia, @jeanmichel-germ, @alexander-4b09, @949laundry, @wilshire, @archidago,
We are still looking for the possible cause of the problem.
Sorry for the inconvenience it caused.
OK, thanks for the information.
@tucnyj @bdd0-info @doonyuen @santosh-thomas8 @avart @tonio-lia @jeanmichel-germ @949laundry @wilshire @archidago
Dear all.
Iâve researched about this issue.
I have three Big sur machines and couldnât reproduce this issue on them.
Please help us to solve this issue by having a remote session.
If you want, please give a Private Message and the time you are available (UTC).
Hello all.
Could you try following command in Terminal?
sudo rm -rf /Library/Filesystems/ndfuse.fs/Contents/Extensions/10.15
Then reboot and run NetDrive again.
Tried with successâŚ
First the prompt came up and I clicked on restart:
Then it crashes and have to force quit
restarted twice and workedâŚ
Itâs a good news!!
We will release a fixed version soon.
Duplicated entries in the extensions list is the cause of the problem.
Here is the fixed version.
Please let us know if this version fixes the issue.
Thanks for your help and patience.
Works for me with the last build.
Itâs working for me! I installed Netdrive as a precaution, reinstalled using your update and restarted the Mac, and then it connected. Thanks very much for your support - I hope it works for others as well.
Thanks. This version works fine. Problem fixed.
