Dropbox authorizes and Netdrive fails to connect, starts the process anew
After upgrading to 2.6.18 build 969 dropbox won’t stay connected. I hit “connect” and chrome shows the authorization button. After I authorize, netdrive shows a “connecting” button and then returns to “connect”. I can continue to do this all day with the only change being a new chrome window each time.
Any ideas?
EDIT 9/29/17: 19 hours with no acknowledgement from Netdrive (which sucks) and I have downloaded and installed the dropbox app. This negates the need for Netdrive. The result is that I am now finding ways NOT to use Netdrive any more. Bad customer service plan, Netdrive.
I have exactly the same problem and it has happened to me starting today. I can not connect to Dropbox.
Facing the same issue. Seems like DB has done some security changes which bdrive needs to look into. Logged a complaint to them about this. Anyone from bdrive here?
nd2api.log shows this interesting line: [ 10300] About::Process failed(400) : https://api.dropbox.com/1/account/info : {“error”: “v1_retired”}
V1 of Dropbox API been retired?
I have the same problem…
yea… same problem here… expandrive also fails to connect… must be dropbox issue/change…
Same problem here… Will there be support for this on NetDrive 2.x? Many, including myself, are choosing NOT to upgrade to NetDrive 3.x (subscription model)
The complete silence on this matter for a week from the developer is mind-boggling.
October 8, 2017, and I have been having this Dropbox connect issue all week. Since Dropbox is the main external drive service I use, this strongly negatively affects my ability to use NetDrive for anything useful.
Some sort of developer feedback would go a long way…
I also have had the same problem for the same length of time. Can we get a response from a developer please?
Having the same issue.
