Can i put drive folder in my local drive?
HI ,
I am using version 3.10.145.
Can I synchronise net drive folder to my local folder?
It is taking too much time for opening any concern Engineering cad part file.
If I can synchronise net drive folder to my local drive folder . it is so easy for me.
Before I used drop box. There was an option like that and I opened any file very fast.
Kamlesh
In line valve ltd
You can add “Local Disk” item to solve your issue.
  1. Choose “Local Disk” in storage type.
  2. Press Connect
  3. Press BROWSE button to select a local folder you want to mount.
