NetDrive version:3.7.687
Windows/Mac Version:windows 10
When starting Quicken, I receive this error The procedure entry point ?asInt64@ValueJson@@QBE_JZ could not be located in the dynamic link library c:\Program Files (x86)\BDrive\NetDrive\nd3api.dll
Hello harry
It’s very weird issue.
I will research about why does Quicken try to load nd3api.dll of NetDrive.
Hi
If you want to troubleshoot using Teamviewer on my pc, just let me know. I am thinking it because NetDrive put this DLL in the Path environment
Hi Jyyoon,
Just seeing if you need anything from me? Thanks for researching this for me .
Hello harry.
Thank you for your kind feedback.
I’ve researched about this issue.
As you guess, it’s caused by “PATH environment variable”
NetDrive add the installed path to “PATH” for a shell dll of NetDrive.
The shell dll is loaded by explorer.exe so adding the installed path is needed.
I will more research about it to avoid this issue.
