Hi there - long time user of Netdrive 2 - just converted and purchased NetDrive 3. Wondering how I add new drives? I can see the menu selection but nothing happens when I select. Cheers,
You can add drive item using the plus button at lower right corner of NetDrive 3.
Add Drive screen will be displayed.
Select your storage type from the drop down list and click the CONNECT button to authenticate. When you finished with the connection you can set options of your drive item and click OK button at bottom to add new drive item.
